Ok, let's see if I can get THIS problem solved. My new "LG" DVD +/- burner has been working GREAT with burning stuff, but specifically with Nero 6, there seems to be one compatibility issue. Before I begin with this explanation, let me say that my burner works with every other burning software that I use, but I guess I'm being spoiled about solving this problem with Nero, because Nero is supposedly the "best" burning software out there. Also, I'm thinking that after someone reads this, they may be able to tell me what I can do to remedy the problem.
When I burn regular cd's, or SVCD's with Nero on my burner, it works with no problems, but when I try to burn a DVD with it, Nero doesn't want to recognize the disc. It keeps saying that I don't have a valid disc type installed. When I try to do the burn, I use a Memorex DVD+RW disc. Like I said before, when I use other burning programs, my burner burns on that disc with NO problems, but Nero won't do it. I've tried burnining, using all the various methods, like ISO, UDF/ISO, DVD-ROM, and DVD Video. I had all the settings correctly set on each burning setting. Nothing works. Is there ANY way that I can get Nero to burn DVD's with this particular burner, or am I stuck with using other burning engines to burn my DVD's? Any help would be appreciated.
Results 1 to 1 of 1
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 13:40
