I used to play OGM files all the time but then I reformated my PC, I installed the OGM codecs and now everytime I play an OGM file the video doesn't responed. It does the "Windows Media Player has encountered a problem and needs to close." At the same time "Windows Explorer has encountered a problem and needs to close." also. It does it with every player(like Zoomplayer), not just WMP.
Is there a way to uninstall every codec & video player from my PC?
Wel, first off, OGM is a media container and not a codec, so make sure that an AVI encoded with the same video codec as the OGMs you are having problems with can be played properly, this will either confirm that it is indeed a problem with playing OGM files or instead may show that this is a problem playing back a video stream using a certain codec such as XviD. I suggest using Gspot to determine this.
If you can indeed confirm that it is the OGM container you are having problem with, ensure, even if you have to do it again, that you have installed the Ogg DirrectShow components (usually has the filename OggDS0995.exe for the newest verrsion)
If it turns out to be a problem with codecs or you just want to remove codecs individually from your system (and if you are on Windows XP, if not, let me know) open up the device manager and expand the "Soubd, video, and game controllers" menu. At the bottom should be "Video Codecs; right-click on this and click properties, then go to the properties tab, here is a list of DirectShow video codecs installed on your system. You can highlight any of them and just click on the remove button.
Edit: Or you can just use DXMan like David K. suggested in another thread.
Hope this helps,
Prospero -
ogg_vorbis_1 (0x674f) Ogg Vorbis
Codec not intalled
I have tried many diffrent OGM files and they all say that.
BTW when I play OMG files I get that green icon at the bottom & 2 of those film icons.....
I think I'll just remove all codecs are instal the OGM codecs again. -
Okay the problem is fixed, I might have install the codec twice or something.
when you see "ogg_vorbis codec not installed" it's talking about the vorbis audio codec. This message is normal in that there is no specific codec for vorbis audio, the Vorbis decoder handles the decoding of Ogg audio. If you click "render" in Gspot and you have the proper Ogg DirectShow filters installed, it will report that the codec cannot be found, but rendering was successful anyway.
Anyway, like I said above, make sure that you have this installed before you do anything, but it sounds like you do already.
http://tobias.everwicked.com/oggds.htm
Oh, and you might install a different XviD distribution (I get mine at www.betanews.com) since most, but not all OGMs use this as the video codec. Or you can download and install ffdshow and tell it to decode XviD files, which is what most people prefer.
Good Luck,
Prospero -
Okay thanks
But I need more help. After removing all the codecs MPEG files arn't working. I tried to install mpeg codecs but they still don't work. -
MPEG isn't the only problem. The only video that runs now is OGM, but nothing else works.....
How to Convert OGM!?!
By SamohAD in forum Video ConversionReplies: 6Last Post: 19th Mar 2009, 18:42 -
.OGM help
By Moparbear in forum Video ConversionReplies: 2Last Post: 3rd Mar 2008, 19:08 -
.ogm to DVD
By Faty100 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 10:14 -
OGM remuxer?
By Colmino in forum Video ConversionReplies: 1Last Post: 25th Nov 2007, 13:27 -
Question regarding .ogm
By Justin Wade in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 12:39
