  1. Which freeware buring programs work the best and have the best quality when burning straight from the files output from DVDshrink. I dont put them into ISO, i just burn straight. My trial for CopyToDVD is about to run out and that works the best. I am going to buy it if nothing can really compare. Guru's please advise.
    Also, what is the purpose of putting the files into one ISO or image file. Is there a benefit to this. It seems to work fine without it.
    Thanks again everyone!!
  2. there is an app here called burn4free (tools on the left). I think (and I am probably wrong) it is the only DVD burning freeware out there.
  3. on your other question. So you don't have a number of files out there would be my guess. You can then use freeware like dvddycrypter to burn the image file.
  4. When i use IMG tools sometimes it doesn't recognize the video_TS file. Why is that???
