when i converted Avi to m2p (SVCD) the file played in wmp with no audio/video synch it played perfect!
when i burned the m2p with Nero and play it in my stand alone dvd player there is a slight audio/video synch....how that can happen?
stand alone dvd players are less tolerant. did you scan for and remove bad frames from the avi before converting?
I said I'll be done in a minute. I meant a Microsoft minute. -
what kind of sync, gradual or continued 2-3 seconds.
Quick answer on continual 2-3 seconds, demux in TMPGENC shave off or add the amount of delay. Remux, burn and watch.
Unfortunately, there are a number of ways and applications to do your conversion, so I would be writing all night giving you all of the possibilities for what could have caused this and how to correct it. Please reply back with more details. -
Its more like continued 2-3 seconds, the problem apear only when playing the movie in my standalone dvd player even when i extract the m2p file again the synch is ok...strangeOriginally Posted by macleod
"some" players have that issue. I use dvd2svcd to backup my dvd's and there is an option that I check that says ">0 second delay", which I mark to 2 seconds. It has on the software a warning message that setting this to greater than 0 will solve desync issues in some players. Sounds like your dvd player is one of those.
Based on what you said about it being a continued 2-3 seconds, I would demux the video/audio and either add or cut 2-3 seconds off the audio, mux it and then it should be in sync. Of course, if you were to play the result in another dvd player, it may be the opposite 2-3 seconds or just play fine.
Audio/video synch problems ... again ...
By Diana (Cda) in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2011, 22:59 -
Video and audio are out of synch when authored
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 10th Dec 2009, 00:39 -
AVCHD audio and video are out of synch
By edong in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Jul 2009, 01:55 -
Video/Audio synch problem
By tangomango in forum Newbie / General discussionsReplies: 2Last Post: 8th Sep 2008, 13:19 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47
