Hello everyone
I've tried looking for similiar topics but cannot find the answer to this.
any help will be appreciated.
I am fortunate enough to have a plasma screen display in my front room, i know i can easily connect my laptop to this for display purposes. I also have a standalone Sony Davs 550 digital decoder.
if i connect my laptop to my decoder via the headphone jack or similar connection and play a Divx with Ac3 sound, should i be able to get genuine dolby digital 5.1 or DTS through my decoder?
Thanks in advance
Martyn
To get the AC3 sound from your laptop to your Sony Decoder you will need either an optical or co-ax digital connection, does your laptop have one of these? I have seen optical out on many desktop soundcards these days, but have yet to find a laptop with this feature.
Not sure if it has, i will look.
in the meantime,
I thought a digital decoder is capable of converting a stero sound into AC3 (or 5.1), the sound you receive from a standard headphone jack is normally stero, would this not do?
Thanks for your swift reply
Martyn -
No, you wont get 5.1 from a stereo signal. You can get Dolby prologic which is 4.1 (left, right, center, mono rears and Sub). So if you are happy with that, then great.Originally Posted by martynuk
Need a non-DirectShow-based AC3/DTS Decoder
By CasanovaFly in forum AudioReplies: 9Last Post: 6th Jul 2011, 04:41 -
Need new non-AC3Filter AC3 decoder from Expression Encoder
By CasanovaFly in forum AudioReplies: 17Last Post: 30th Jun 2011, 17:41 -
What is an inexpensive ac3/dts decoder?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 7Last Post: 19th Dec 2010, 13:17 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 19:44 -
can i record laptop video to standalone dvd recorder via firewire?
By beatz2005 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 17th May 2007, 09:54
