I capture at 720x480 MPEG2 using MMC. Never had a problem before. Reformated my hard drive now having troubles. Using TMPGE 2.56. I can load the video but it wont load the audio. It used to before. So its making me demux them and load them seperate. But also now when I go to source range the video hangs up when Im trying to fast forward. I never had any of these problems before. I did a search and everyone keeps saying raise the priority of directshow, but if I raise it above the mpge2, tmpge gives me an error when I try to load the video that says it is not supported. Here is a pic. Thanks in advance.
Boxingjunkie
For some reason the pic wouldnt load but here are my settings.
MPEG-2 Video Plug-In 2
Directshow Multimedia File Reader 1
TMPGE Project File Reader 1
AVI VFW Compatability Reader 0
AVI2 (Open DML) File Reader 0
BMP/PPM/TGA/JPG File Reader 0
Wave File Reader 0
Uninstall nimo codec pack first. I had all sorts of errors after loading that including standard widows codecs not working. Everytime attempting to play a file media player would try to download a codec even for a .mpg or an uncompressed .avi. Not being able to ff is classic symptom of codec being unavailable. Audio dont show in tmpgenc cause it thinks codec is not installed. Solved my probs by re-installing media player (uninstall present version first). In future only install codecs you need, not bulk packs with conflicts.
I would try installing a DVD player like PowerDVD, and media player and direct show will then use it's codec. all you then need do is raise direct show above the built in deocder and all should be well...... -
I reinstalled Win DVD 4. Reinstalled WMP 9. Installed the free DVD Codec that comes with it. When I open a clip in WMP, it says error sending codec. The clip does play and has audio, but the name of the clip is in orange and when you click on it, its giving this error message. I also uninstalled the Nimo Codec Pack. Opened the clip in TMPGE and had the same troubles. If I give the highest priority to the Directsho, it wont even let me load the clip, but if I keep the MPEG 2 Codec with the highest priority it will at least load the clip. Also, it is showing two mpeg 2 plug ins. They are exactly the same codec. How do I go about getting rid of one of these? Thanks for the help.
Thanks Boxingjunkie
AnyDVD HD troubles
By neroguy in forum Newbie / General discussionsReplies: 10Last Post: 24th Oct 2008, 13:17 -
Subtitle troubles
By ROOK1E in forum SubtitleReplies: 1Last Post: 1st Aug 2008, 03:48 -
ipod troubles...again!
By SE14man in forum Newbie / General discussionsReplies: 11Last Post: 12th Nov 2007, 20:52 -
TV Out Troubles.
By SE14man in forum Newbie / General discussionsReplies: 54Last Post: 11th Oct 2007, 16:55 -
Terrible PC troubles..
By SE14man in forum Newbie / General discussionsReplies: 9Last Post: 29th Sep 2007, 14:04
