  1. Hello,
    I am using DvD workshop to make dvds but I have major problems:
    Prob1 I setup a new dvd and select videos, go to menu but when I select menu templates and press next it says"an unsupported action was attempted"then it closes and I have to start again (tried reinstall but no luck)
    Prob2 when I select record to disc it says I need 8.2gigs free( I have 8.9 free) then neer the end of the processes it says I ran out of space!!!!!!!
    Somebody please help because I have to burn the DVDs with nero and there is a Lot of flickering and stuff!!!!!!!!!!
  2. I feel your pain. I also have DVD Workshop
    For problem #1: Don't use templates. I stopped using them and create all my menu's from scratch. The templates do not save you much time anyway. I currently have v1.3, but have seen this problem since v1.0
    Problem #2: You are probably running out of space because of temp file storage. I don't know any answer to this other than to try to free up some more disk space.
    I don't know why you are having trouble with Nero. I often use DVDWS to create the title set and then burn it with RecordNow. Have not seen any flickering like you describe.
    I have used Nero in the past without problems.
    Just what is this reality thing anyway?
