Hi,
I have managed to create a 5.1dd DVD-R from avi files with AC3 (5 channels).
When I play the disk through my Home Theatre and TV the sound is very tinny & not quite right. This is very frustrating as it took me AGES to work out how to get 5.1dd on a DVD-R & I thought my troubles were over when Dolby D apeared on my amplifier when I played the disk!
My process was as follows:
1: Run .avis file through VirtualDub Mp3-Freeze. Repair any bad frames.
2: Join the avi files together & extract wav
3: Fix the wav with Ac3Fix
4: Convert the avi to m2v with TMPGEnc Plus
5: Use the fixed ac3 file & m2v file in DVD Lab
6: Compile to DVD with DVD Lab
7: Burn with Nero
As I mentioned, I do get what I have been craving from the above process but the 5.1 sound is just not quite right!![]()
If anyone can help me & put me out of my misery it would be much appreciated!!
Hi .
Sorry i can't help u, but if someone can.. let me know cause i have just bought a dvd burner and are starting to make dvdr with 5.1 audio.. Have u downloaded a sample of 5.1 audio and burned it?? Does it sound like the ones u self have created?? -
Micol,
are you extracting the audio using Vdub? if so, what exactly are you doing?
I you're selecting audio -> full processing. File -> save wav
then you will get a stereo only file, and Vdub is perhaps not decoding it correctly (the tinny sound)
If you're selecting audio -> direct stream copy. File -> save wav then ok.
Is AC3Fix reporting any errors, or trying to repair anything?
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
