Hello,
My four-month old Sony DRU AX500 (internal, 2x) used to work fine, but now has difficulty recognizing the disc I insert--both movie discs and blank discs. It starts making cranking kind of noise for a while and stops after a minute. The Windows 2000 says "Insert a disc". Sometimes it recognizes the disc after I have inserted it 3-4 times; sometimes it just doesn't.
Once it recognizes a blank, the writing part has been okay, for the most part. Occasionally, it fails to finalize after writing; Nero just sits there ticking away the time meter, but the writing doesn't finish. I am forced to re-boot; interestingly, the DVD-R plays, so I haven't minded it too much.
Any suggestions about what I can do? Will it help to buy a disc cleaner thingie (which kind)?
Thanks.
Ash
You have to let us know what media you are using & what firmware, these are 4x machines, not 2x when you have the right firmware
1. Onr problem has nothing to do with the media. The Sony has problems recognizing a DVD video disc I insert with the intention of viewing or ripping. Sometimes it works after I put it in several times; sometimes it fails altogether to recognize it. (I am talking about good original discs that play on other DVD drives and stand-alone DVD players).
2. The second problem is: the same thing happens often with blank media. I have to insert and eject several times before it recongizes it as a blank (e.g., using Nero's Media Info command).
Almost all the times, I have used 2x DVD-R and DVD+R (I rarely use RW). Brand names I use are TDK, Fuji, Imation, and Meritline generic.
3. I didn't know it could work at 4x. I have stayed with the firware it came with.
Thx.
Ash -
No, you need the better firmware, it was made to make it more compatible with media types & to get it to recognize any media. Its free firmware. Only takes a minute or two to download & install .....other than that your laser might be dirty.
2 suggestions:
- Try a newer firmware - my DRU500A runs the latest firmware 2.0f and I have no problems with it
- Sony provides also a drive check utility (same page as firmware updates). Run that and if your lucky, it'll say your drive is no good anymore and you'll get a nice new DRU510A under warranty.
Good luck -
Thanks, folks, for taking the trouble to deal with my troubles! Couple
more questions if you don't mind.
1. I couldn't find the place from where to download the firmware. Where is it? At Sony site?
2. How do I clean the laser? Do I just go to BestBuy and get one of those laser lens cleaning thingies?
Thanks.
Ash -
http://sony.storagesupport.com/dvdrw/dru500axdwn.htm1. I couldn't find the place from where to download the firmware. Where is it? At Sony site?
Use compressed air in a can. You can get some at pretty much any computer store.2. How do I clean the laser? Do I just go to BestBuy and get one of those laser lens cleaning thingies?Geronimo -
Hello Geronimo,
Thanks. I downloaded and tried to use the DriveCheck software, but a basic problem. My Sony DVD burner doesn't recognize the CD-R blank. It's a Catch-22! At least, now I have a number I can call.
Sorry for a basic question. I have one of those cans. Where do I aim the air flow? Is it enough to eject the tray and squirt some air inside and hope for the best?
Thanks again.
Ash
Sony HDD download difficulty
By doccah in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Jul 2008, 23:23 -
Best burner for reading DVDs
By samijubal in forum DVD & Blu-ray WritersReplies: 15Last Post: 23rd May 2008, 12:21 -
Dvp5982 reading dvds as data files
By themow in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Mar 2008, 22:52 -
Compatible DVDs with Sony DVDRW DRU-700A
By dzachau in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2008, 15:25 -
Unplayable dvds made on Sanyo DRW-500
By ronl44 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 6th Dec 2007, 13:25
