I recently recorded something using pinnacle pctv deluxe device. I now want to take the commercials out, what is the best way to do this without loosing quality. What program should i use to burn or can I still use the burning tool incorporated with pctv deluxe?
i have tmpge dvd author and tmpe plus 2.53
but still playing around with these and I'm obviously not doing something right.
thanks in advance for any help
There should have been some type of pinnacle editing software that came with your capture card. If not, IMHO Ulead video Studio 7 is the best for mpeg editing. You could also try the v-dub mod, Its easy to use, but I have had difficulty saving the edited video. As for burning, I use nero, but just burnt a DVD-R using Burn4Free, and it turned out to be a very easy to use, capable, high quality product .You can find Burn4Free in the tools section.
Just shut up and listen dumbass -
Did you try Womble MPEG-VCR so far best for cutting mpeg2 without re-encoding.
Pinnacle Studio 8 and DV home video editing (ver.9 already home)
Delete commercials keeping the right timing of the subtitles on a MPEG TS?
By edea in forum DVB / IPTVReplies: 4Last Post: 21st Oct 2011, 17:19 -
Trying to record ONLY commercials
By Ch3rryC0ke in forum DVB / IPTVReplies: 7Last Post: 12th Sep 2011, 12:21 -
Anyone here want to make some spec commercials?
By twells22 in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2010, 15:45 -
Editing Commercials
By Jacks_Daddy07 in forum EditingReplies: 2Last Post: 18th Oct 2010, 23:09 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10
