I always make my movies in dvd utf 1.02 version as ive found dvd video wont work on my dvd player
If i burn my dvd files onto dvd and have the dvd set as dvd utf? instead of dvd video, will it still show the menus and allow you to select different videos to play or will it skip this and star the first video?This is putting 15 separate music videos onto a dvd
You can find two cool Nero guides here
http://dvdshrink.info/nero-video.php
http://dvdshrink.info/nero-udf-iso.php
For authoring problems check the Guides and Tools sections on the left
<--------You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
subtitlecreator modified to support utf-8 and utf-16
By amtm in forum SubtitleReplies: 3Last Post: 6th Aug 2014, 17:44 -
How can I force my Video Converter to read Unicode UTF-8 subtitles?
By MoneyHoney in forum SubtitleReplies: 7Last Post: 27th Apr 2012, 19:13 -
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Unicode UTF-8 or UTF-16
By Ronaldo in forum SubtitleReplies: 2Last Post: 2nd Jun 2008, 23:37
