Hi,
I have an mpg file, I'm trying to burn it with nero and it say that is not a standard file the problem is on the audio and suggest me to continue without encode or re-ncode again with nero.
I have tried to demultipelx and re-multiplex with TMPGenc but i receive an error during multiplexing.
I have tried to use the method suggest in a guide on yr. forum reguarding remove badframes with virtualdub mp3 freezer but it doesn't found bed frames..
Thanks in advance for yr. help.
b. regards.
You say that nero says that you have a non-complaint file. What happens when you burn this ?, does it work ? if so you will not have to do anything else you are talking about. Try burning it and if it does not work on your stand alone we can then start to look at possible causes.
Russ -
Well, I have not tried but in the past when i have the same problem and contine to burn the same and after i tried to play on dvd player the risult was video ok and audio only the beginning and i don't want to lost another cd...
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Problem authoring mpg file with ffmpegx
By blue439 in forum ffmpegX general discussionReplies: 5Last Post: 14th Dec 2011, 13:23 -
A/V sync problem when remuxing (AverMedia mpg file)
By matomato13 in forum Video ConversionReplies: 8Last Post: 25th Mar 2011, 21:48 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
