Hi,
Just recently I have noticed the inclusion of audio filter graphs in virtual dub in order to manipulate audio.
The problem is that the footage I have captured only has audio on the right hand audio channel the left has static. I wish to discard the left hand channel and split the right hand channel to make a false stereo or mono audio track.
I have tried various filter combinations in virtual dub but all seem to lead to a virtual dub lockup and crash.
Does anyone have any clues where I might be going wrong?
You could do this in GoldWave, SoundForge or some other sound editor if you extract the audio track in virtualdub first (Save WAV).
Doubleclick on the filterlist in the following order
input-stereosplit-discard-output
Will remove one of the audio channels and give you a mono output
input-stereosplit-output-discard
will give you the other channel as a mono output.
Hope this helps.
Virtualdub filters in avisynth-faster? How to use them?
By salidarius in forum EditingReplies: 10Last Post: 3rd Mar 2011, 21:13 -
Could I get some advice on which VirtualDub filters to use?
By ryangarfield in forum RestorationReplies: 8Last Post: 1st Jan 2011, 00:26 -
import VirtualDub filters into Vegas?
By Srivas in forum EditingReplies: 8Last Post: 8th Oct 2008, 05:49 -
question about virtualdub resizing filters
By gutsmanx in forum Capturing and VCRReplies: 2Last Post: 30th Aug 2007, 12:55 -
virtualdub filters
By demonwarrior in forum EditingReplies: 5Last Post: 9th Jun 2007, 05:27
