Where are the subtitles stored in a DVD ?
In the Vob file or IFO ?
Cause I got a DVD now and I want to add subtitles.
Do I have to re-author the whole dvd or can I just add them to the vob/ifo file ?
VOB. The VOB files are MPEG2 files that contained multiplex (aka muxed) video (m2v) audio (ac3 or PCM) and subtitle streams. These are know as elementary streams.
Combining your elementary streams into a single (or several) VOB file/s is know as multiplexing (aka muxing), but is more commonly called authoring. It's when you author the DVD that you define the chapter points, VTS, menu links, etc. This info is stored in the IFO files.
Read the 'what is DVDR' section to the left for more info.
To answer your question. You need a program that can author DVDs with subtitles. The only programs I know of that can do that are: DVD Maestro, Scenarist, Reel DVD, Adode Encore and IFOEdit. The first two cost ~$3k, the next two ~$550 and IFOEdit is free
You'll need to have your subtitles in SUP format for IFOEdit to mux them.
See the guides here and at http://www.doom9.org for authoring DVDs with IFOEdit (there is also a tread running on this currently and several others if you do a forum search). -
I gotDVD maestro but last time i tried adding the subs, they came out black so I couldn't read them.
doom9 doesn't say anything bout changing color of subs. -
Scenarist is at LEAST $15,000. Maestro was roughly $30,000 with the inclusion of the MPX series encoder card.
Yeah I got Maestro, but I can't figure out how to change the subs color ....
DVD structure
By gbabione in forum DVD RippingReplies: 6Last Post: 19th May 2010, 23:41 -
HD DVD Disk Structure?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 7th Jan 2009, 00:58 -
authoring existing DVD structure
By bumbrlik in forum Authoring (DVD)Replies: 3Last Post: 6th Jan 2009, 19:02 -
create dvd structure from a .vob
By forare in forum Newbie / General discussionsReplies: 6Last Post: 12th Sep 2007, 04:13 -
Fix DVD file structure
By pchan in forum DVD RippingReplies: 6Last Post: 31st Aug 2007, 23:17
