Can anyone help me out with the Menu Properties window? What exactly are all of the restrictions. Some of them are obvious, however, I'm still not exactly sure what PTT Search / PTT Play, Time / PTT Search, Still Off, Pause On/Off, Disable Chapter Skip, Line 21 Support, Button Selection/Activiation are. If anyone could explain what the restrictions all mean or if someone can tell me where I can find a guide that explains these that would be much appreciated. Also, I am having some trouble with subtitles. I have 8 movies and 8 separate subtitle menus on my disc, so far I only checked it in PowerDVD, but when I turn the subtitles on, some work and some don't, all the settings are the same however. If someone knows a detailed explanation of how to do subtitle menus, that would also be appreciated.
Sad how one would spend all that money on a program and get stiffed on a user manual. Complain man ....complain
You should riot at Spruce's now defunct HQ - probably an empty warehouse building in the bad part of town.
Originally Posted by holistic
Stalker: Did you get a help file?
I feel likeso here's your secret present this year. Maybe the Easter Bunny can give you the sub info.
Title Play (the ability to jump to a different title by entering a title number using a DVD player remote control)
PTT Search/PTT Play (the ability to jump to or play from a new Chapter
Time Search/Time Play (the ability to jump to or play from a new time by using a remote controls numeric keypad)
Stop (the ability to stop movie playback before the end of the movie)
Resume (the ability to resume movie playback)
Time/PTT Search (the ability to locate specific points in a video stream by entering an exact time; this is frequently used, for example, in educational applications, sometimes in association with bar-code reading features of industrial DVD players)
Still Off (the ability to prevent holding of a still image from video; this ability is supported as Slide and Still Show features)
Pause On/Off (the ability to pause movie playback)
Forward Scan (the ability to scan forward through the disc)
Backward Scan (the ability to scan backward through the disc)
Next Program (the ability to skip forward through chapters)
Previous Program (the ability to skip backward through chapters) -
lol, very funny all.
The restrictions are a way to tell the player to ignore certain input. For example, selecting Pause would disable the pause button, so someone could not pause the video at that point. Same for the rest, Chapter skip, you can't skip chapters, etc. i am not sure what all of these specific ones are for, but you get the idea. -
I read (i think on this forum) the manual for dvd maestro is a monster book and is pretty useless.
http://groups.yahoo.com/group/dvdmaestro/
Join this group. You can d/load a windows help file (drag/drop into your installed dir) and a pdf verison of the manual (if you lost yours or it has been damaged).
PS - this is NOT a warez group or link. It's a discussion forum for the program. It's not very active right now, but reading the past messages can be very helpful.
I learn more about my programs just playing around with them and reading the archive of online sites then reading the manual (good example, CCE basic)
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 11:42 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 01:32 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 03:22
