  1. anyone know if the E3Works DVD-Rs are worth buying? I've heard they arn't that great, but what is the general consuses on this brand?
  2. I'm interested as well...anyone tried these ????
  3. Been using them for 3 weeks now and have yet to have a problem - future shop has them on sale for 39.99 for a 25 pack (obviously Canadian), until Thursday.
    Sep 2003
    Toronto, Ontario, Canada
    pussyguru, what burner do you use? Do they burn at 4x?
  5. I have a Sony DRU 500A (2.0f) and they do burn at 4X
    1. Media ID please?
    2. Maybe a pic or description of what the disc looks like on top? The
    3. And where did you get these? E3works CD-R are great. Not seen DVD-R.
  7. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    I bought a 25 pack of those at Future Shop and had to bring them back.
    I have a NEC 1300a firmware 1.05. When I tried to burn them they only showed up as 2x but even so I had an error msg saying it could not write to the media. Tried at least 5 discs with 3 or 4 different write sotware. They seemed like they tried to write but then the software came back with the msg after a couple of minutes. Fortunately, none of the discs were damaged. I had bought a 25 pack 2x Pine brand -R a week earlier at Future Shop and they work fine with my burner.
  8. Pre-recorded Information:
    Manufacturer ID: LEADDATA01
    Physical Format Information:
    Book Type: DVD-R
    Part Version: 5
    Disc Size: 120mm
    Maximum Read Rate: Not Specified
    Number of Layers: 1
    Track Path: Parallel Track Path (PTP)
    Linear Density: 0.267 um/bit
    Track Density: 0.74 um/track
    Bought them at Future Shop (Canadian retailer)
    http://www.futureshop.ca/catalog/proddetail.asp?sku_id=0665000FS10032033&catid=12501&a...WLBS=fs%2Dweb3
    And as for picture of them they are simply silver tops with no markings.
    I hope this helps
