does anyone know how to correct tempgenc (correct settings) to fix audio/video alignment ? i want to make a lossless mpg2 file from the vob's (gonna put it on a dvdr) but its always out of sync![]()
pace1025,
here's a radical idea...at least i haven't seen it mentioned in the post yet...but eh...sue me if some1 already said it b4...
when i ripped 10 Things I Hate About You into SVCD, the audio was outta sync continously throughout the entire movie..there's a filter in tempgenc called "source range"...under that filter there is an option for "audio skew" this allows tempgenc to insert audio earlier or later, depending on what # u put into "audio skew"...(i think a negative # makes the audio start later)..if you wanna encode the entire movie...then under that filter...just set start frame and end frame as the beginning and end of the movie, respectively
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 14:21 -
error while burning DVD DL using tempgenc dvd author
By rgpai9972 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2009, 21:15 -
tempgenc authoring works 4 - can I save the edited clips?
By yvonne_1980 in forum Authoring (DVD)Replies: 2Last Post: 24th Mar 2009, 05:59 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 21:39 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 01:35
