hi there,
is there a program out there where i can convert a 5000 frames bitmap sequence into an avi unsing a codec (=not uncompressed)?
i know that it is possible in premiere but my ram ends at 40 seconds so i have to do it in several pieces what i do not like.
Results 1 to 10 of 10
Aviedit (a modified version of the one that Microsoft released years ago) does it quite well. I use it often.
http://www.am-soft.ru/
I am not having any luck adding bmp sequence in TMPG to encode. I keep ending up with only the first picture. Any help????
bugande, it depends on the filenames, I think. It's quite similar to segmented avi files. If you have a image0001.bmp, image0002.bmp, image0003.bmp and so on till image9999.bmp, TMPG will load all these .bmp files. Just select the first one (image0001.bmp) as video source and save it as avi or mpg.
On 2001-10-02 12:31:18, Betamax wrote:
Use VirtualDub
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
How do you do it with VDub? -
hi folks,
i found out that i made a mistake in premiere converting the bitmapsequence into an avi. when you import the sequence mind to enable the button "sequence" in the import dialog. then the files are not beeing loaded into ram so there doesent seem to be an limitation by ram.
this is for people having the same problem. thanx for your support and have a nice day.
How to Convert a Unicode SRT file to bmp or idx
By rezabrando in forum SubtitleReplies: 12Last Post: 19th Jun 2015, 10:15 -
Tool to convert SWF (actionscript) to uncompressed AVI or image sequence?
By Koppel in forum Video ConversionReplies: 5Last Post: 1st Jul 2011, 13:23 -
how to convert BMP to AVI ?
By monks19 in forum Video ConversionReplies: 2Last Post: 2nd Apr 2010, 15:08 -
how to edit a (super 8mm) bmp-sequence?
By WMR in forum EditingReplies: 1Last Post: 17th Dec 2009, 15:40 -
BMP to AVI sequence
By max_e_mum in forum EditingReplies: 6Last Post: 17th Aug 2009, 05:57
