I'm not sure what's happening but I just bought a spindle of 100 Princo 4x DVD-R's and my Sony DRU-500a is only able to burn them at 2x (it actually seems slower than 2x). I'm not sure why this is happening because I've read posts of users who had the same burner and burned these DVD-R's at 4x with no problem. Could it be a software issue? So far I've tried RecordNow Max 4.5 and Nero Burning Rom and got the same 2x results.
Results 1 to 13 of 13
i have SONY DRU 500AX but i think it is the same , and i have burned sucsessfully the same spindle of 100 Princo x4 whit it .The only diference is that i use Veritas Record Now DXv.4.6 that came whit my burner...
the solution is easy ...... throw the princos in the trash they are crap disks anyway ..... seriously ... check that you have enabled dma mode for the sony drive.
Boy, now that's a surprise!Unable to burn Princo 4X DVD-R's on Sony DRU-500a at 4xICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
What Firmware are you using?
If time is money then I am traveling back in time. -
Hi I use this Media with this drive and get a x4 Burn with STOMP
Have you defraged the Hd with the file on ? untill I did I only got x2 also it maybe worth checking any Anti virus software isnt checking at the time.CHEERS GARRY -
I'm using the latest firmware for the drive which is 2.0f. I'll give the defragging a try and disable my antivirus program when burning. This seems to be a media problem since I'm able to burn 4x TDK and 4x Memorex DVD+R's with no problem. Although I'm not having any playback problems with these Princo's that fact that they're 4x and burn only at 2x sucks.
Sonys dont like Princos, use Accus, you can get 4x from them & they are very reasonable priced....
those with a 510 can use sonys new software to read dvds 8-12x lucky:
http://sony.storagesupport.com/dvdrw/dru510adwn.htm -
Just discovered something weird. I just burned a Princo at 4x and then burned one right after it which burned at 2x (it was the exact same movie). I guess this proves that you get what you pay for. I'm definitely going to give the Accu's a try. Thanks for the advice.
i have got same burner and use red datawrite classic 4x disca
have had no problems all have burnt ok.
if you want to copy dvd's use shrink 3.0 its incredible. -
Ive burnt 25 working movies on princo 4 x media that work fine, (Pioneer A06) then I bought another spindle which im getting all kinds of read errors on, lock ups, skipping, im going to try another brand to confirm it was a bad batch of discs. Will let you know results...
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
Unable to burn DVD, unable to access the Video_TS.ifo.
By Asymmetry in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2008, 00:02 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 12:52 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
