I recently downloaded a movie off the internet but when i went to play it the video and audio are not in sync. My computer is fast enough to play them as this is the first one out of hundreds that has screwed up. What is causing this? and how do i fix it if possible. I suspect it might be a bad encoding job, is there a way to fix this?
Try encoding it at 29.97 fps and then play the encoded file back.
That has fixed my sync problems before
see, if the audio is ahead of the video, you ned more frames for the video to keep up with the audio.
Now if the video is ahead of the audio(rare), then you decrease the fps to encode at to 23.967 or 20.
29.97 should fix it though
DivX Audio problem which has always bugged me..
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2011, 08:36 -
Avi to Divx audio problem
By win993 in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 17:53 -
DIVX DVD Player Audio Synch problem
By wulf109 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Mar 2008, 08:14 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 04:38 -
DVD to Divx conversion - Problem with audio ! Please Help
By sharartie in forum DVD RippingReplies: 1Last Post: 23rd Aug 2007, 04:13
