I have a Title that I just burned to DVD-RW and when I select a Subtitle, it is really bold, almost unreadable. Is there an option in EditIfo that I must enabled/disable/change?
Yep - you need to cut and paste the subtitle format and colours from the original IFO into your newly authored one.
If you look in the guides they will tell you how to do this in detail...
Cheers,
Rich.
unreadable greek subtitles
By ioakim in forum SubtitleReplies: 8Last Post: 12th Mar 2012, 08:45 -
By ioakim2an in forum SubtitleReplies: 1Last Post: 17th Aug 2010, 06:52 -
unreadable DVD becomes readable - why? how?
By JohnnyBob in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:11 -
Saving Unreadable DVD's Part Deux
By hitechluddite in forum Authoring (DVD)Replies: 21Last Post: 14th May 2009, 10:51 -
Can you make a dvdr unreadable?
By nuffskillz718 in forum Newbie / General discussionsReplies: 11Last Post: 27th May 2007, 05:13
