Hi All,
I have looked on several places and could not find guide for DVD-Audio.
I have panasonic home theater music system and it support DVD-Audio. I have tried to create a mp3 and wma disk using nero but can not play on my dvd player. Does any know how to create a DVD-Audio disk? Am i mising something or something is wrong with my dvd player?
My dvd also support wma format, I created one disk but could not play on my dvd and IDEAS?
Thanks- B
Results 1 to 10 of 10
You cant burn DVD-Audio disks. They aren't the same as DVD data and video disks. And very very few DVD playes support MP3 DVD's (Data DVD with MP3 files on it)
Thayne- Thanks. If i can not burn DVD-Audio disk then what is the use of it? I mean why it support this feature which I can not use- B
I think the question is: if you have a DVD/CD player that accepts discs with mp3's on them, then will the player read the TOC on a data DVD filled with mp3's and play them. Probably not, NE else tested this?
EDIT: also you need to clarify. Are you talking about a DVD-Audio disc or a data disc with mp3's on them. There is a DVD-Audio format. Very VERY high quality sound but not many players support it yet.
http://www.digitalaudioguide.com/faq/dvd-audio/faq_intro.htm -
Skynet107- It is not possible for DVD player to read MP3 as a data. My DVD player say it support DVD-Audio and Windows media. I tried to burn a DVD-RW with bunch of WMA file and it is playing ok on my pc but "no Play" on my panasonic DVD.- B
Some do, like the lite-on DVD player, but mos dont.Originally Posted by Bhola
I have a Panasonic F65 and it doesn't support DVD-MP3 and AFAIK no Panasonic does,but my player supports DVD-AUDIO(2ch).If you want to make a DVD with MP3 then I would use WinOnCD or Ulead PictureShow.
BTW..Diskwelder sells programs that will make a DVD-AUDIO disk but they start at $500USD. -
It may support commercial made DVD-audio disks, but you can't make them with DVDR disks.Originally Posted by Bhola
There are ways to get audio only DVD's, kinda, but they are not DVD-Audio. You could combine a bunch of tracks as a wav, or encode as AC3 or mpeg-1 layer 2. Then create a video with just a still picture to span the length of the audio track, then create a DVD out of that. Then when you authour the dvd you could put chapter marks at each song so you could skip between them during playback. -
WinOnCD will not make a DVD-AUDIO disk but it will author a DVD with MP2 audio,you can fit more songs on a DVD using MP2 than LPCM(DVD-AUDIO).
This thread might help:https://www.videohelp.com/forum/viewtopic.php?t=173624&highlight=winoncd
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
How to create DVD disk using Pinacle studio 12
By 1234567 in forum Newbie / General discussionsReplies: 4Last Post: 30th Oct 2009, 12:32 -
Won't create .img disk image
By LoafingOaf in forum ffmpegX general discussionReplies: 1Last Post: 13th Feb 2008, 11:02 -
How to create HD video on disk?
By mlong30 in forum DVD RippingReplies: 3Last Post: 28th Jul 2007, 17:00 -
Can't create DVD on DL disk HELP!
By mlong30 in forum Authoring (DVD)Replies: 2Last Post: 18th Jun 2007, 09:29
