HeY everybody,
I Just have a query about dvd WS;I made a dvd menu with several buttons, now on the preview thing in WS I can see the highlighted buttons
but when I create a dvd directory and burn it in nero I cant see the Highlights on my dvd player.Can Anyone help Me pleasseee?!??!??!?!?!?
The update patch from Ulead fixes this problem with 1.3 that effects some standalones.
Why are you using Nero to burn though, as the Ulead engine burns excellent UDF DVD Compliant Files/title sets. Good solid burns that play on any player I've tried. The Ulead burning engine not only sorts the order correctly, but also, only includes relevant files and anything that shouldn't be there like lay files from spruce compilations, are ignored. Use it just as a burning engine, whatever I've compiled my title sets with, works every time for me.
Hope this helps.
intensity pro quick couple of questions
By digitalpimp in forum Capturing and VCRReplies: 8Last Post: 31st Dec 2011, 18:22 -
New here - Quick questions
By ImportGuyR34 in forum Authoring (DVD)Replies: 6Last Post: 10th Mar 2011, 08:11 -
A Couple of Quick Avidemux questions
By Seeker47 in forum EditingReplies: 3Last Post: 16th Mar 2010, 04:20 -
Couple quick Panasonic AG-1970 questions
By pgoelz in forum RestorationReplies: 13Last Post: 4th Mar 2010, 18:22 -
Hi havent done much dvd burning in awhile and had quick question
By pitten247 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 21:10
