Ive had limited success using this program.
After it wouldnt create the dvd folders after half a day and no activity, i tried program streams separate to create the converted files that i would then put into ifoedit to make into vobs
Whats the best settings to do, i have ulead movie factory but that always wants about 8gbs of hard space to author from the mpg files and doesnt convert the audio.
And Dvd lab is crazy with it complaining about screen sizes.
How can i get svcd2dvdmpg+ fully functional to do the dvd folders at first attempt. Ive tried it with only two mpgs before of about 700 each, and also of 3 mpgs totally about 2.3gbs
Ive looked at past questions etc but still no success, ive made two movies from the program streams method and then into ifoedit, but now my 3mpgs totally 2.3gbs doesnt get past the first mpg
Looks like ive wasted a Fiver if someone cant solve this mystery why i cant get half as much productivity out of this program
They only way svcd2dvd (version 1.5, if you don't have it download it with manual update) will not do what it is suppose to do is when you got mpgs that aren't the right format svcd or vcd. Could you tells what what mpgs your using and what width, height, fps and audio bitrate they have.
Another think what could happen is you don't have enough discspace. you need 2 times the input mpg size as free disc space.
Greatings,
Yf -
Ok here are the details
Firstly i tried installing version 1.5 but thqat pc aint on the net, i copied files from net and put them where i should but still it wantedto launch the net, i had the same program getting the nromal version1. and especially with getting nothing out of this program at all, im losing hope
All the Mpg files are
fps 25-pal
horizontal - 352
vertical - 576
size 480x576
aspect ratio 4:3
File Sizes
Mpg 1 - 795
Mpg2 - 829
Mpg3 - 795
And audio is 4400 for all as i know i need to convert to 48k for dvd.
I have 10gbs of hard drive space so that rules out that element -
ok can you email me your log file?
It will be in C:\Documents and Settings\Chris\Local Settings\Application Data\Badgersoft\SVCD2DVD\1.5.1326.35434 or your equivalent. The file is called svcd2dvdlog.txt
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Philos31Guest
I have this problem too.
Found out that the Mpg files I was working with are actualt .dat files just copied from the VCD.
I used MPG Header repair to repair them and after it it works...
Woeld be an idea to put a bit of repair in SVCD2DVD maybe....
DVD Folders - Video TS & Audio TS
By bdr13278 in forum Authoring (DVD)Replies: 20Last Post: 21st Feb 2010, 13:40 -
Vob's, Avi's & Video_TS folders....
By SPORTSGUY88 in forum MacReplies: 35Last Post: 20th Jul 2009, 00:20 -
DVD to MKV with multiple audio & subtitle streams?
By RarelyEvil in forum DVD RippingReplies: 1Last Post: 18th Jun 2009, 11:30 -
OSX Program to Extract streams from .m2ts?
By marklight in forum Video ConversionReplies: 1Last Post: 12th Sep 2008, 00:27 -
Program to just pull certain streams of audio.
By vodmare in forum AudioReplies: 5Last Post: 9th May 2007, 00:07
