How is this drive? Is it worth to buy for $150. Please help.
IMO anything HP is a waste. I would suggest getting this dual format NEC drive for only $135.
http://avlogic.com/product.cgi?code=18030059 -
I really don't like HP drive.. they are good for 12 month, then they always die.. (4 drived died in my hand) Stay away. Pioneer A06 would be the best bet, or the NEC drive if you don't mind using Hacked firmware
um...the hp drive IS an NEC drive. eithet 1100 or 1300, i don't remember which, this drive has nothing but good reviews if you do a search on it.
It sure looks like NEC ND-1100....
You can prolly get NEC ND-1300, rebadged as 'Mitsumi' for less (model DW-7802TE).
Or Mitsumi DW-7801TE --- NEC ND-1100. -
The NEC ND-1100(4x,+RW) is going for as little as $99 and the ND-1300(4x,-/+RW) for $115,online prices are usually better than retail.
www.pricegrabber.com
Office Depot CD-R bad or not?
By bevills1 in forum MediaReplies: 4Last Post: 10th Aug 2010, 13:59 -
office depot's ACTIVA brand
By Tom81 in forum MediaReplies: 0Last Post: 27th Nov 2007, 20:29 -
Office Depot Brand 16X DVD
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 19Last Post: 29th Sep 2007, 00:55 -
Acer 22" Wide Screen Monitor $179 at Office Depot
By ebenton in forum ComputerReplies: 8Last Post: 20th Aug 2007, 16:03 -
Office Depot brand dvd-r/ Ritek seconds?
By dnix71 in forum MediaReplies: 5Last Post: 31st May 2007, 20:15
