how u do u overburn bin/cue file using nero? thankz!
n wah is the best blank cd-r media use to burn vcd?
in the options tab, it will have a check box for overburn and then lets you specify by how much.
Just to say you've been told about this, overburning could cause a problem with both your dvd player and your burner. It could cause the burner to "break". The dvd player may not be able to read it.
Don't know if they are old wives tails (I have done marginal overburning aka 5 meg over) and on one of my VCD's the end skipped. Didnt verify what it possibly was (i.e. bad CD or whatever), by cd burner is still fine, my dvd player is fine. I just heard it and wanted you to make an informed decision.
VOB File and CD overburn Query
By scott274 in forum Newbie / General discussionsReplies: 8Last Post: 17th Nov 2009, 02:54 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 10:08
