I usually do 34 min/CD to maintain the best possible quality. However, is there anyway to do a 50 min SVCD w/o suffering a loss in quality? 34 min on a CD is just too short - but I don't want to take a cut in quality. I tried to burn a VCD last night...which can take over 60 min/CD. My gosh the quality is bad.
I'm beginning to think that DVD is my next option...but the only drawback is that it will take longer time to encode and it's not easy to make a copy. I hate all of that ripping crap. A 34min clip to SVCD takes me 2 hours to - if I do a DVD (which will likely be 1.5 hour clip) how long will it take? Any ideas?
My PC is 2.2Ghz P4.
Not easy to make a copy? hahahahahahahaha! -
use tmpgenc and do a two-pass VBR. set the motion search to "estimate." try a small sample to see if the quality is good enough.
will take more time but quality should be okay. just batch encode while
you're sleeping.I said I'll be done in a minute. I meant a Microsoft minute. -
Originally Posted by honorarybrutha
If you use CVD resolution (352x480) to create your SVCD's then you can lower the average bitrate even more. The lower CVD resolution doesn't need as high a bitrate to maintain quality. I find 1400 avg. is acceptable."Art is making something out of nothing and selling it." - Frank Zappa
mkvmerge - no quality loss?
By gustav32 in forum DVD RippingReplies: 1Last Post: 20th May 2009, 14:56 -
Encoder with no quality loss
By JamesDV in forum MacReplies: 25Last Post: 8th Apr 2009, 11:01 -
Ultimate quality to store on hard disk AND playback on a Xbox 360
By SimonG156 in forum Video ConversionReplies: 6Last Post: 28th Jul 2008, 08:13 -
video quality loss
By majax79 in forum Video ConversionReplies: 2Last Post: 24th May 2008, 01:03 -
MPG2 capture bad frm 40min to 50min marks, exclnt qlty before and after?
By tonytbaloney in forum Capturing and VCRReplies: 6Last Post: 5th Feb 2008, 15:57
