hi, i'm making a dvdr compilation with short films from people from all over the world(belgium, equador, finland, usa, uk, japan, italy) can you please help me with these questions:
what can i use/do the best to make the dvdr playable in all countries. or do i have to make dvdrs for each region? i'm using idvd on a g4 mac os9.
is it possible to make tracks looping automaticly? can i program this in idvd?
is idvd a good program anyway? i would like to make an introduction movie, than the title and then the menu, is this possible?
what dvd+or -r or something else can i buy the best?
is there an online shop that sells them for a good price (in europe?)?
please let me know anything you know, it's the first time i make somethng like this so any advice is welcome. thanks, floris
To answer your first question, iDVD creates DVDs that are region free. You will be able to share them with anyone. If yo uuse a more powerful DVD suthoring program, such as DVD Studio Pro, then you can set what region to compile in, Region Free [also known as Region 0] being one of those options.
For looping tracks automatically, I do not believe you can do this in iDVD. You would need ot use DVD Studio Pro.
You want to stick with the DVD-R not the DVD+r Standard for now. This is because playback of DVD+R media on a lot of DVD players in circulation right now is not supported. Although any player introduced in the past few years should play them just fine, it is safer to go with the DVD-R. Besides there is no major difference between the two in functionality and in price for DVD Video Authoring, when using ±R as opposed to ±RW.
Hope this clears some things up. Try searching http://froogle.google.com to find the best deal for media.
Video Compilation
By redcapeman in forum EditingReplies: 4Last Post: 27th Dec 2010, 05:01 -
When Ripping Compilation CD's...
By Nitro89 in forum Off topicReplies: 3Last Post: 1st Nov 2009, 08:48 -
DVD compilation.
By Benhermies in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2008, 11:46 -
Making compilation DVD?
By chronic777 in forum Authoring (DVD)Replies: 8Last Post: 19th Jul 2008, 12:19 -
compilation music tracks.
By scarlac in forum DVD RippingReplies: 5Last Post: 31st Jan 2008, 03:39
