Is there any way to make a vcd with dvd style menu screens? Like with a on screen pointer to make selections with. U know, use the arrow keys and make a selection...blah blah blah. I'm just tired of having to make them where u have to use the number keys to make selections.
thanx
from what I read, the VCD specification does not support menus like that.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
take a look at Roxio Videopack 5.
here's a link for the guide:
http://www.coyote01.freeserve.co.uk/video_pack_5.htm
but it costs about $300!!!I said I'll be done in a minute. I meant a Microsoft minute. -
but does that allow you to select with arrow keys? it still looks like it's associating a number with each menu option....
to clarify my original post - you can make nice menus for vcd, no doubt. but I'm pretty sure that moving around with the arrow keys is not supported in the vcd spec - you still have to select your option with the number pad.- housepig
Housepig Records
out now:
I have eliminated having to use the number keys to make a selection with VCDEasy. I create mpg stills of DVD-like menu pages and can navigate using the [<< and >>] keys. It works great!
In this example the selected episode is outlined, but you can use just about any paint program to create cursors, underlines, pointers, etc.
I'm pretty sure VCD does not support using the arrow keys. -
still at work right now so i haven't been able to try VP5 out yet. just printed out the guide and skimmed thru it. sounded like you can make chapters that you can navigate with the arrow keys, not the number pad. will let you know once i get home to try it out.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
Want to create Really Cool DVD's ???
By Deter in forum Authoring (DVD)Replies: 40Last Post: 4th Jan 2010, 23:34 -
Cool Edit Pro 1.2a
By rixware in forum AudioReplies: 15Last Post: 14th Feb 2009, 18:07 -
I just listened to my first podcast - cool!
By yoda313 in forum Off topicReplies: 3Last Post: 26th Sep 2007, 16:17 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07
