Why does my player show 2 sets of black bars (one light black, the other dark black), when I play anamorphic dvds ?
This player was hacked via remote for multi region and I would like to know how to get it back to original factory settings ?
One of you must have an answer![]()
go here https://www.videohelp.com/dvdhacks.php?select=Mustek+DVD-V520 ..... do the region hack but instead of selecting multiregion code (255 or bypass depending on which hack works on your player) set the code for your region eg 1 for america 2 fo uk etc it will then be back to factory settings .... however i doubt this is what is caursing your problem,check some of the other settings on the player eg tv type (ntsc/pal) or video output (rgb/s-video/yuv (set it to rgb))
Firmware for Mustek DVD Recorder R100A
By Spot.Zwei in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Jan 2011, 10:49 -
Code Free for Mustek Yukai MP76A
By eagle1200 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 12:14 -
mustek yukai mp76A problem multi zone
By mustek in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Jun 2008, 21:47 -
Mustek R100A just died!
By mcgeechan6600 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Oct 2007, 10:14 -
Mustek V56L-5E DVD player How To Reboot remove YUV P-Scan setting
By ImNoSmarterN5thGrdr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Aug 2007, 09:32
