on their webpage it says cinemacraft will work on windows 98 and a celeron PC, but when i try to run setup it says my PC doesnt suppor enhanced 3DNOW or SSE. whats the go? it says it'll work on a celeron on their website.
Intel(R) CeleronTM Processor series
Products (533A MHz or greater) released after Mar. 30,2000 are being supported.
yeh i just read up on that. so there is strickly NO way at all i can use this proggie???? if so thats pretty shit.
a low-end celeron cp isn't too expensive an upgrade
(us $30-50) and actually isn't too dificult to do yourself
as long as you are patient and careful. You'll have to
be brave enough to open up your PC case, though. -
yes thats no problem for me. ive installed a new video card cd burner and harddisk without any troubles at all. The intel chipset on my motherboard is extremely cramped though. its very very hard to get to.
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 16:51 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 20:09 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
