  1. When I backup some DVDs, there is no sound in the resulting files.
    Actually, in both films this has happened to (Y Tu Mama Tambien and Saving Private Ryan), there is sound in the menu. Also, with Y Tu Mama Tambien, I can hit the "Next Audio Track" button in PowerDVD and hear the commentary (I didn't try this with Private Ryan).
    I'm not making any changes so what gives?
    Thanks.
    Oh yeah, at the moment, I'm using v3.0
  2. Member wulf109's Avatar
    Jul 2002
    DVD Shrink does not correct the ifo files to properly reflect the streams used. You must select the first audio stream listed in the DVD Shrink window if you want your audio to autoplay.
