Hi People
I am trying to create a SVCD with DVDMF2 of a widescreen AVI (562x240 if I remember correctly). When I run it it stretches the image to fullscreen, with everyone very tall and thin on 4;3. I edited the DVDMF2 .ini file for advance settings and was able to add the advanced selection. From this I chose 16:9 but the resulting SVCD was still not in the correct ratio.
Does anyone know how make further changes in DVDMF2. The boxes for resolutions are greyed out.
I have created a VCD mpeg1 with correct ratio in Tmpeg (don't have mpeg2 capability after trial period). I was able to keep the aspect ratio. Only mpeg2 encoder is in DVD Movie Factory is there any way to create plain mpeg2 files here in variable resolutions?
Anyone got any bright ideas.
VCD isn't bad but would prefer SVCD.
Luap
Results 1 to 9 of 9
It works for me.Originally Posted by luap_bopper
When you say the SVCD was "still not in the correct ratio," what specifically do you mean?
Jerry Jones
http://www.jonesgroup.net -
The ratio is still too tall and thin when played on 4:3 TV. It definately worked in that it letterboxed the image, it just wasn't quite right. With Tmpeg I was able to keep the aspect ratio, do my mpeg (mpeg1 only) was correctly letterboxed.
Thanks anyway
Luap -
Sorry that last sentence made no sense. Preview before posting.
I should have said with Tmpeg I am able to keep the correct aspect ratio and it letterboxes correctly. This is only mpeg1 as I don't have mpeg2 facility with Tmpeg or I could create with that and author with VCD Easy, Nero or DVD Movie Factory.
Cheers
Luap -
Why no MPEG-2 facility?Originally Posted by luap_bopper
I'm curious.
Jerry Jones
Thanks Guys
Too cheap to buy full version with mpeg2 as it mpeg2 encoding part of DVDMF2.
Cheers
Luap
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
Movie Factory 6+ with HD-DVD Plugin
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 25th Oct 2010, 12:20 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
