Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I have a Pioneer DV-343 player and it plays everything fine except for DVD-VCDs. The audio is fine but the video is shaking up and down. Looks like very bad interlacing.
    Input files were NTSC video 352x240, audio 44.1khz
    I am wondering if there are any Pioneer owners who make DVD-VCDs and are having the same problems as me. If I re-encode the video to 352x480 and then create a DVD-VCD, the video is fine but there is a loss of quality. The quality of VCDs are bad enough, I don't want to lose any quality when putting them on a DVD. I am hoping there is a fix or some sort of Pan and Scan technique to make a 352x240 frame become a 352x480 frame to fix it. Any comment is much appreciated.
  2. You can use the option pan&scan in svcd2dvd.
    Greatings,
    Yf
