I have created an avi file from an rm file using tinra and when attempting to sync the audio, using the "Change so video and audio durations match" option, it just doesn't.
It displays the framerate it is going to use next to the option, and it has 1.5 fps (or thereabouts) displayed. If I manually set the framerate, it should be about 8.5.
My avi file is 30 mins long, the rm file is 22 mins, so why does virtualdub think it should set the framerate so low?
Thanks in advance
Si
Results 1 to 1 of 1
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 11:35 -
Video Audio Sync Problems
By Johnnysh in forum DVD RippingReplies: 11Last Post: 26th Jan 2011, 01:47 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 07:51 -
Trying to sync audio with edited video, problems with encode....
By Jensen in forum EditingReplies: 1Last Post: 5th Jan 2008, 08:20 -
Help! VirtualDub video/audio out of sync when enconding MPEG2 to XVID
By kbal in forum Video ConversionReplies: 6Last Post: 19th Dec 2007, 15:05
