I have an Xvid file that virtual dubs file info indicates that no key frames are present. Is there away to insert k frames or will I have to reencode?
Thanks in advance,
VC
This is so much fun!
when you browse for the file to open there is a box you havve to check called extended pop up options or something like that. then you check rederive key frames.
Thanks for the advice. I really want to convert this film. I suppose that after i rederive the key frames I should resave the avi?
This is so much fun! -
you can either save the new avi or frameserve it to your encoder without saving it.
How to Add subtitles to avi Xvid files !!!!
By prithvi in forum Newbie / General discussionsReplies: 11Last Post: 12th May 2011, 09:05 -
Are variable keyframes possible?
By x2x3x2 in forum Video ConversionReplies: 15Last Post: 7th Aug 2010, 07:40 -
What is the best way to cut up an Xvid file or add chapters to it?
By Chrushev in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2010, 05:14 -
How do you add switchable .idx / .sub to dual audio .AVI (XviD)?
By NextJinGamer in forum SubtitleReplies: 4Last Post: 1st Jul 2008, 16:42 -
want to add forced subs to divx/xvid files
By gossipninja in forum SubtitleReplies: 3Last Post: 23rd Jul 2007, 03:26
