Hi,
I used to use BlindWrite for burning from cue/bin. Now I decided to give latest CdrWin a try.
Now I have 2 problems :
1. My CD-RW (RIcoh 7120) doesn't appear anymore in the BlindWrite drop-down list. It used to work perfectly before and I don't understant what happened here.
2. Cdr-Win burns SVCDs fine, but when I try to read the SVCD on my PC, it justs says "Incorrect Function".
Now I'm quite unhappy since I can't burn cue/bin anymore, neither with CDr-Win nor BlindWrite.
Please help ! Is it something with the ASPI drivers (I use Win2k) ? I installed LSI aspi for Win2K without any success.
I precise that Nero works ok.
THanx
Snow-white Waldok
(someday, my SVCD will come...la la la)
give vcdimager easy a try with cdrdao. I use TSVC also with cdrdao...300+ cds and going strong.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
