  1. I am trying to encode an Avi Movie tp MPEG-2 in Mainconcept MPEG encoder but i have tested a small sample taken from the main movie but it is really dark compared to the original and i have searched through the program but i can't find any settings to brighten it up as far as i can see and hope somebody knows if it is at all possible to do this in this prog,Thanks..
  2. I don't think you can add what could be considered Effects in MainConcept. You are better off doing your encoding in TMPGEnc
  3. You can use virtual dub to frameserve to main concept. vdub has a lot of filters including brightness/contrast filters to make the film brighter. You can also boost washed out colors using vdubs filters and sharpen images.
  4. On frameserving, does anyone know if the Main Concept Encoder will reliably read AVISynth scripts? Reason I ask is that I am very impressed with the quality and bitrate allocation that MC achieves in a single pass, but every time I feed it an .avs, the next time I try to run MC it refuses to run at all! I then uninstall/reinstall and it works OK again (for one encode). The XP error report mentions sonething about quartz.dll. TIA.
    Budgie
