ive downloaded a few DVD rips . ive VCD'd em to just normal VCD, (352x240) but since the res. is too small, the quality stinks!. so i used SVCD (480x480), the still picture quality is very good and sharp but moving picture is horribly pixelated. there is so much block noise. its terrible. makes it really bad to watch. DOES ANYBODY KNOW HOW TO ELIMINATE BLOCK NOISE FROM SVCDS?? ive been searching for the answer to this for AGES. The source AVI file was not like this. When it is encoded it goes really bad. can someone PLEASE HELP ME HERE??!?!?!!!! i really would appreciate the help here. Im using 2200 bitrate. Is there any other setting that can help to reduce block noise that is independant of bitrate?
<font size=-1>[ This Message was edited by: Yeshi on 2001-10-02 01:08:52 ]</font>
Closed Thread
First, burn a CDRW with a bunch of test clips just to find out what is the maximum bitrate YOUR dvd player will take. Mine plays SVCDs very well up to 2800 (almost).
Then encode your video using CCE SP (CinemaCraft Encoder) version 2.5 or 2.62, using 3 pass variable bitrate and setting the maximum to your max. Make sure to check or un-check the "upper field first" checkbox depending on whether or not you get slight jitters during playback.
If you´re using W2K it may be a bit tricky to get CCE working properly, but it can be done (I do it). The way to do it is in some of the forum discussions.
I get SVCDs that actually look better than the original VHS tapes. The key words are "look", cause I know they cannot *be* better, and "better" cause its a very subjective term... But I am very demanding in terms of quality and I´m satisfied...
good luck.
E.Baldino
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 15:51 -
Multi-colored block noise bug in Adobe Premiere - DV video
By tat2jr1 in forum EditingReplies: 0Last Post: 23rd Jan 2010, 02:20 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
Make SVCD from prepared directory
By Gimballon in forum Authoring (VCD/SVCD)Replies: 2Last Post: 18th Jun 2008, 07:35 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37
