Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Guest
    Hi, I'm just started to work with Svcd2dvd+ and sofar I'm impressed by its preformance.
    Easy to use, good tuturials the first program that is doing wat it promisse!!
    I've had 2 Svcd converted to 1 DVD, worked fine in Powerdvd and played in my sandalone (JVC).
    I'm using a surround theater system (JVC) and somehow the audio isn't played trough the system but only on the TV.
    Is this normal, or did I do something wrong?
  2. Have to try that for you with my surround set let you know.
    Greatings,
    Yf
