I have been using ZoomPlayer lately, I like some of the features it offers, but I am having trouble playing AVI files encoded with XVID codec. When playing, as in my other players, I get color blurs all through the video as the ZoomPlayer is not using XVID as the "default" codec. I know (I believe) you can setup ZoomPlayer to use different filters, as different videos may play better with and even require different codecs. How can I setup a "filter" to be used for playing by ZoomPlayer, and how can I then select the appropriate filter to be used for various videos? For instance, some AVI's may require "mpeg-4 fast motion" and some may require "xvid".
Patrick
Well, you could mess with the manual filter settings in the Zoom Player configuration, but I don't know how much this will help you.
I would suggest that you download and install ffdshow instead. This will allow you to specify what decoder DirecShow will use to decode specific media. It also includes its own decoder that I and others have found to be very reliable. After installing it, just open its configuration menu throught the Windows Start Menu and click on "codecs" here you can choose which decoder will be used to decode which codec. "libavcodec" is the ffdshow decoder.
This way, your decoder choices aren't limited to Zoom Player, but will work with nearly every player out there, including WMP.
Let me know if this doesn't help, and we'll see about coming up with something else.
Prospero
P.S. MPEG-4 fast motion is an encoding option, the decoder used doesn't have to be a fast-motion decoder, but handles it automatically.
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 06:31 -
How to Get an .avi file with Soft-Coded (On/Off) Subtitles
By Spiralagnus in forum SubtitleReplies: 3Last Post: 20th Nov 2010, 14:00 -
How to Watch 720P Coded AVI on Standard TV
By gonwk in forum Newbie / General discussionsReplies: 10Last Post: 23rd Dec 2009, 15:27 -
Rip hard-coded subs from avi - VirtualDub filter and SubRip problems
By jujuandhuhu in forum SubtitleReplies: 4Last Post: 25th Oct 2008, 14:16 -
I want to rip hard-coded subs from a VCD (avi format)
By lostinlodos in forum SubtitleReplies: 8Last Post: 22nd Jul 2007, 21:43
