Could someone tell me what the differnce is? I'm starting to use WinDV for capture and dont know what setting to use.
Thanks.
If you want to open the DV-Avi in virtualdub, use type2. Most other editing apps (though maybe not all) are happy with type 1. As for the difference between the two types, ask Microsoft.
I was told w/ DV 1 it interweeves the video and audio into 1 stream but w/ DV 2 the audio and video are seperate streams.
DV 2 is more compatible w/ older software and VFW software i've found -
So you think I should use type 2? I just dont wont to find out down the line that I choose the type thats not compatible with software I may want to use.
Use type-2. As long as you are in Windows type-2 is a safe bet since it's still based on VfW and any Windows NLE/capturing program should be able to use it. The advantage of type-1 is because audio is not redundantly reproduced as a separate stream within the file (as in type-2) it has a slightly lower bitrate, and is easier to export back to a DV camcorder with (unless your are using a program designed specifically to capture and export in type-2 like Premiere).
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59 -
type 1 or type 2 capture-newbie
By sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 19:22 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 21:16 -
Convert Type 2 DV to Type 1 (DVdate?)
By nlec in forum Video ConversionReplies: 30Last Post: 30th May 2007, 14:52
