Hi all,
Im trying to make a backup copy of Das Boot . Its a dual sided DVD and Im not sure how to go about it. I made an image(ISO)of both sides with DVD Decrypter but am unsure what to do next. Am I on the right track or...?
I understand the fact that Ill have to compress the video in order for it to fit on a single DVD and for that Ive always used DVD Shrink.
I guess Im asking for a way to join the two sides together so that I can "shrink" the resulting file enough to fit on a single DVD disk.
TIA,
DBZ
the easiest thing to do, is rip both sides in file mode with dvd decrypter. then use tmpg dvd author to put the 2 titles together, then run that through dvd shrink, then burn
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 16:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 22:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 11:40 -
Help, my PC can't read miniDVD dual-sided
By ssalim in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Oct 2007, 08:55 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 05:04
of both sides with
