Is it possible to convert an XSVCD to plain old SVCD? If so,
how do I go about doing that? AVICODEC tells me this XSVCD is:
File : 558 MB (0.0 B), duration 0:00:00, type MPG, 1 audio stream(s), quality 88 %
Video : 0.0 B, 15000 Kbps, 29.970 fps, res. 480*480 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 0.0 B, 192 Kbps, 44100 Hz, 2 chan., 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
I have tried de-multiplexing, and then trying to convert the
video to 2000 kpbs and then multiplexing... seperating the
audio to a .WAV and then reencoding...nothing seems to work or
give me something I can burn to a CD to watch on my DVD player.
I have four (4) of these XSVCDs and their sizes are fairly
normal as far as MPEGs go:
571480KB, 592700KB, 648576KB, and 677369KB
If I try to de-multiplex one of these X(S)VCDs with TMPGenc,
the first thing that happens is a new box opens that says
"Creating GOP List" which takes about 30 seconds to complete.
Not sure what this means nor how I use a "GOP List"...anyone
know anything about this??
Closed Thread
One topic is enough. If you want to bump it just reply to it.
https://www.videohelp.com/forum/viewtopic.php?t=174568&highlight=
Help with .TS Conversion
By a2234548 in forum Video ConversionReplies: 1Last Post: 1st May 2011, 13:15 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 10:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 19:36 -
RM Conversion
By Seeker47 in forum Video ConversionReplies: 3Last Post: 11th Apr 2008, 13:16 -
Conversion
By firoril in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 11:46
