  1. I have 3 *.bin and *.cue files comprising of video. When setting up the program I selected the bin\cues I wanted processed and authored. Have not had a problem prior to this. I recall seeing a topic or "bug" report detailing an issue with file names and/or folder names having improper structure (using undescores or dashes, something like that.). Is this still a problem? Using the above scenario (3 *.bin\cue files), the program starts and then just sits... log even says its starting but I no longer see the moving bar at the bottom of the program screen....
    What do you need to help me resolve this?
    Thanks!
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you paste your log file here. It is found in your equivilent of:
    C:\Documents and Settings\Chris\Local Settings\Application Data\Badgersoft\SVCD2DVD\1.5.1326.35434\svcd2dvdlo g.txt
  3. As soon as I get home. I did not have this problem prior to doing the "automatic" updates over the last few days.
    Thanks!
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Yes but is it the same source files as a couple of days ago?
  5. No they are not the same..... I'll get the log file to you as soon as I can. When I get home I am also going to try different bin\cues to see if there is a problem with my source...
    Thanks!!!
