I've got an mpg - clip with a text (logotext) and a counter all through the clip. Is it possible to get rid of this ?
raufman
Hi,
In the Tools section on this site there is a tool called EditStudio. (Here is a link to their own site, http://www.puremotion.com/editstudio/new/index-effects.htm).
If you scroll down you see their so-called "Knockout" effect. The demo file looks fine to me. You can dowload EditStudio for a free trial, so you can check out whether it does the job for you.
Note, though, that the pros and cons of video editing programs depend on other things as well, so check out the other features (particularly the quality of its encoding if you will be burning DVD) before actually making a choice.
Frank
Remove duplicate text from SRTs
By cal_tony in forum SubtitleReplies: 8Last Post: 4th Jun 2014, 10:31 -
How do I remove unwanted text in movie
By rocks911 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2011, 10:35 -
Remove text from file properties
By Pegsitron in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2010, 07:29 -
How to remove text from MKV?
By Lastbreath in forum EditingReplies: 1Last Post: 2nd May 2010, 04:34 -
remove text while converting?
By aussiemac in forum Video ConversionReplies: 2Last Post: 18th Aug 2007, 21:29
