hello,
i remember reading a while ago a guide that was created to just use Ulead DVDWS or MF to just create the menus and then using something else to put the DVD together.
I really like DVDWS, but on this last DVD i'm trying to create it is making a mess of the video output. video stutters at different points while the audio keeps running smooth. very strange never seen this before.
was hoping to find this guide again on how this person made their menu in DVDWS with using a small dummy movie file and then taking the output of that project and using another appliction to create the movie vob files and merge them together.
any help would be appreciated! thanks, marc
Originally Posted by msimon7
For example, my Panasonic DVD camcorder records MPEG-2 at the high quality (Xtra) setting and these clips exhibit the following attributes:
NTSC drop frame (29.97 fps)
MPEG files
24 Bits, 704 x 480, 29.97 fps
Field Order B
(DVD-NTSC), 4 : 3
Video data rate: Variable (Max. 8800 kbps)
Audio data rate: 256 kbps
MPEG audio layer 2, 48 KHz, Stereo
So this is my cue to set my project settings in Ulead DVD Workshop to precisely match these attributes.
The result is a cleanly burned DVD - with perfect playback.
Have you carefully matched your project settings with the attributes of your SOURCE?
Jerry Jones
http://www.jonesgroup.net
Create menu but not convert
By xxxThiefxxx in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2011, 16:49 -
Create Menu with 2 or more pages
By Phototechman in forum AudioReplies: 2Last Post: 15th Feb 2010, 09:37 -
Ulead videostudio clipping guide
By Bjs in forum User guidesReplies: 4Last Post: 26th Nov 2008, 14:23 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36 -
Create new menu to link to existing menu. Possible?
By Noy2014 in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 12:22
