PLEASE HELP!!!!! IVE RUN OUT OF IDEAS!!!
i cannot seem to burn a SVCD without a 1-2 second lip sync delay when i play it on my DVD player. i know my DVD can play SVCD, ive got some ive bought that work great! i am using NERO 5.5.9.14 now but have also tried EASY CD/DVD 6 and get the same problem. i have tried the SVCD compliant menus in NERO on every setting, MPEG2/MPEGAV and entry VCD/SVD, and still no joy![]()
I NOW NEED A EXPERT..........PPPPLLLLLEEEEAAAASSSSEEEE!!!!!!!!!
More info needed:
What's your source?
What do you do in each step? encoding, authoring, burning etc. What apps do you use? What settings in those apps?
Have you read and followed any guide found at this site for "??? to SVCD"?
/Mats -
hi
thanks for answering.
i have SVCD from a lot of different sources, some downloaded and some ripped and encoded myself. all of the MPEG2 files ive got play perfectly on my PC, no lip sync problems at all.
i then try and burn using NERO 5.5.9.14 using the SVCD panel, i have tried the compliant menus and used all settings...same results. the discs play on the PC with no lip sync problem, but when i play them on my DVD player theres a delay of 1-2 seconds!
i have other SVCD ive bought and they work great!!!
i have spent a long time looking through "HOW TO"s on this site for weeks and still havent found an answer.
im right here if you need more info, cheers
If you have a SVCD compliant mpeg, I strongly suggest using VCDEasy (the latest free version) to author it. Uncheck the "Burn" checkbox, and VCDEasy will just create the cue/bin CD image files.
Then burn this image to CD with Nero, using "Burn image" under File.
If your problems persist, it could be that you're using a too high bit rate. Even if your player plays SVCD, not all can handle max SVCD bit rates. Try lowering to around 2000 kbps total (A+V).
/Mats -
What player are you using? The Toshiba SD220E/SD210E suffers from this problem. There are fixes available - see threads under the DVD Players section of this forum or the DVD Players review section of this site.
have you checked for and deleted bad frames before converting? use vdub mp3 freeze. it and the guide are in the section to your left.
I said I'll be done in a minute. I meant a Microsoft minute.
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 17:36 -
Media Player Classic Lip Sync
By rckowal in forum Software PlayingReplies: 2Last Post: 9th Jan 2011, 13:31 -
Formula for NTSC to PAL lip-sync
By macnab in forum Video ConversionReplies: 4Last Post: 11th Aug 2010, 11:16 -
dvdauthorgui bad lip sync problem
By prioryjim in forum Authoring (VCD/SVCD)Replies: 5Last Post: 2nd Dec 2009, 05:47 -
IC For Lip Sync Correction
By SingSing in forum AudioReplies: 3Last Post: 4th Jun 2007, 16:53
