  1. ATI's AIW MMC v8.5 displays 4 recording presets in the Personal Video Recorder tab of the properties. Does anyone know how to change the 4 present to display presets of user’s preference instead of last used.
    I have the AIW RADEON 7500 for what its worth.
    Thanks in advance
  2. Just select the preset you want to change, then click the "map preset" button to change it to the profile you want; either selecting a pre-made one or creating a new profile.
  3. Also be sure to get the latest version of Guide Plus so that your custom presets will show up when you go to schedule a recording.
