New version looks great but I tried a 3 VTS NTSC Menu (2 seperate tests of 3 different mpgs) and got following stackdump each time:
Exception: STATUS_ACCESS_VIOLATION at eip=004057EE
eax=00000000 ebx=009A0F18 ecx=00000000 edx=00000000 esi=009A0F18 edi=00000000
ebp=0076EED8 esp=0076EDF0 program=C:\WINDOWS\LOCAL SETTINGS\APPLICATION DATA\BADGERSOFT\SVCD2DVD\1.5.1326.35434\BC735A24-D272-11D7-A3A1-00D009D2C4BF.EXE
cs=01B7 ds=01BF es=01BF fs=63F7 gs=0000 ss=01BF
Stack trace:
Frame Function Args
0076EED8 004057EE (00435C34, 0076F060, 00000000, 00000002)
0076EF18 0040662C (00000000, 0076F060, 00000002, 610CB050)
0076EF88 00407E87 (00413820, 0076F060, 00434370, 00000003)
0076EFC8 004082F6 (0076F060, 009A04B0, 009A04B0, 00410230)
0076FA68 00409D88 (0000000F, 009A07D8, 009A0328, 0076FAF0)
0076FDB8 61007408 (610D1F58, FFFFFFFE, 0000000C, 610D1E7C)
0076FE08 610076ED (00000000, 00000000, BFFC9490, 0076FF68)
0076FE28 0040E0D2 (00408580, 037F0500, 0076FF78, BFF8B560)
0076FE38 0040103C (00000000, 81D62EF4, 00560000, 33376342)
0076FF78 BFF8B560 (81D85B34, 00000008, 81D62EF4, 00000044)
64778 [main] bc735a24-d272-11d7-a3a1-00d009d2c4bf 452975 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
65440 [main] bc735a24-d272-11d7-a3a1-00d009d2c4bf 452975 handle_exceptions: Error while dumping state (probably corrupted stack)
Built all VTS VOB, IFO & BUPs. Died making Video_ts.ifo.
Any ideas?
Results 1 to 13 of 13
frogman709Guest
can you email me your log file?
C:\WINDOWS\LOCAL SETTINGS\APPLICATION DATA\BADGERSOFT\SVCD2DVD\1.5.1326.35434\svcd2dvdlo g.txtSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Resolved in latest update.
Sorry to say but I'm having the same problem, see the stackdump below
eax=00000000 ebx=0A0412C8 ecx=00000000 edx=00000000 esi=0A0412C8 edi=00000000
ebp=0022F038 esp=0022EF50 program=C:\Documents and Settings\Pa\Local Settings\Application Data\Badgersoft\SVCD2DVD\1.5.1326.35434\66ff0733-5910-4f10-9899-9b37eaceb369.exe
cs=001B ds=0023 es=0023 fs=0038 gs=0000 ss=0023
Stack trace:
Frame Function Args
0022F038 004057EE (00435C34, 0022F1C8, 00000000, 00000002)
0022F078 0040662C (00000000, 0022F1C8, 00000002, 610CB050)
0022F0E8 00407E87 (00413820, 0022F1C8, 00434370, 00000002)
0022F128 004082F6 (0022F1C8, 0A040A78, 0A040A78, 00410230)
0022FBD0 00409D88 (0000000D, 0A041038, 0A040328, 6107CDD0)
0022FF40 61007408 (610D1F58, FFFFFFFE, 000007E8, 610D1E7C)
0022FF90 610076ED (00000000, 00000000, 00000001, 823F6070)
0022FFB0 0040E0D2 (00408580, 037F0009, 0022FFF0, 77E614C7)
0022FFC0 0040103C (FF000000, 001A0D00, 7FFDF000, F27B9CF0)
0022FFF0 77E614C7 (00401000, 00000000, 78746341, 00000020)
End of stack trace
I've already dl the update, but no results, the strange thing is that I was able to get a menu before, I'm using SVCD2DVD since a couple of days now, after cleaning up my system and reinstalling (after format) this weekend the problem with the menu started. Most likely that the automated update has tricker the problem.
HELP????
OS is Win XP -
Same here after update used to work fine with the initial release. Trying to create NTSC menu.
eax=00000000 ebx=0A041338 ecx=00000000 edx=00000000 esi=0A041338 edi=00000000
ebp=0022F028 esp=0022EF40 program=C:\Documents and Settings\RRx Scorpion\Local Settings\Application Data\Badgersoft\SVCD2DVD\1.5.1326.35434\8b465678-50aa-4b4b-be51-8034bb502008.exe
Stack trace:
Frame Function Args
0022F028 004057EE (00435C34, 0022F1B8, 00000000, 00000002)
0022F068 0040662C (00000000, 0022F1B8, 00000002, 610CB050)
0022F0D8 00407E87 (00413820, 0022F1B8, 00434370, 00000002)
0022F118 004082F6 (0022F1B8, 0A040AA0, 0A040AA0, 00410230)
0022FBC0 00409D88 (0000000D, 0A041078, 0A040328, 610D2F2A)
0022FF40 61007408 (610D1F58, FFFFFFFE, 00000FE8, 610D1E7C)
0022FF90 610076ED (00000000, 00000000, 00000001, 867F5048)
0022FFB0 0040E0D2 (00408580, 037F0009, 0022FFF0, 77E814C7)
0022FFC0 0040103C (FF000000, 001A1E98, 7FFDF000, F1183CF0)
0022FFF0 77E814C7 (00401000, 00000000, 78746341, 00000020)
End of stack trace
Here is the log from the menu creator... Could it be this error causing the problems?
Starting to build menu....
Save bg as jpg....done.
++ WARN: [mpeg2enc] No aspect ratio specifed and no guess possible: assuming 4:3 display aspect!
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File C:\Program Files\Badgersoft\SVCD2DVD\silence.mp2 looks like an MPEG Audio stream.
**ERROR: [mplex] Unable to read from C:\Documents and Settings\RRx Scorpion\Local Settings\Application Data\Badgersoft\DVD MenuMaker\1.0.1331.37297\6a508747-d571-4450-91e0-ab9046e35f2b\background.mpv.
saving sub....done.
saving preview....done.
create sub file....done.
running menu muxer....MUXRATE =4400
max_sub_size=0
warning: no subtitles added
done.
create menu meta file....done.
PS I have tried with both jpg and bmp to no avail. -
Could it be your background files aren't the right size? Which program did you use to make them.
Greatings,
Yf -
Guest
Mine does the same too, It was woeking fine now it doesnt build the munu ifo file.
"I wish I had turned auto update off"
Apart from this it has been working fine, Please reolve this quickly.
I have a stackdump file that is a exe file what do i do with this -
Reading the replys, I'm wondering can I reinstall SVCD2DVD (the file that was original send after donation) and before I start the prg can I diasable autoupdate.
I've already tried it to uninstall and reinstal, but on first start it is going to autoupdate!?
Again how to disable the autoupdate before the prg start the first time.(maybe in the windows register?)
regards William -
Here is a trick you can use.. deinstall and then unplug your internet connection and reinstall.
Greatings,
Yf -
I'm aware of the issue and will resolve it tonight. I works if you configure for 120 frames. (i neglegete to test for 1 frame).Please reolve this quickly.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Going to try the 120 setting, thanx for the heads up Chrissyboy you are always on top of things! Much thanx again.
120 Frames did work... however, now when I hit the menu button to get back to the title it does not work. My DVD player says "Playback Only" and just continues through the movie playing. Also when I FFwd and try to resume it auto skips to the next chapter instead of where I wanted it to resume from. Just thought I should let you know. Chrissyboy all your hard work is very appreciated. Even with the minor bugs here and there this program is by far the best out there for this type of conversion. My hat is off to you as well for your prompt responses and constant updates.
The "stack dump" bug has been resolved.
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 24th Nov 2010, 00:36 -
Menu creation in Encore CS5
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 16th Aug 2010, 14:17 -
Menu Creation in DVDAuthorGui
By larrytxeast in forum Authoring (DVD)Replies: 3Last Post: 23rd Jul 2010, 12:52 -
DVD menu creation
By andrewgerm in forum Authoring (DVD)Replies: 4Last Post: 28th Aug 2008, 16:24 -
Newbie menu creation question
By dinkob in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 13:49
